05.11.2008, 04:21 AM
you need to leave expansion room for heat. 80% allows the dif fluid to expand. if you fill them full then when it expands, it pushes out past the seals. like above, just fill to the cross pins and you'll be fine. if you need it tighter, put thicker oil in
