Originally Posted by blueb8llz
this is my first brushless setup and i want to hard wire the mmm wire onto the wire of the feigao 7xl. my question is...how is it done? back on my brushed motors i would just solder the wire onto the motor tab.
do i interlace/mesh the wires and then just solder them together? the wires from the motor are very stiff too. and what color to what color do i match the mmm and 7xl wires with? should i electric tape them first before i solder the wires together? any help or tip appreciated.
I would just solder the exisiting wires together, and its not as simple as what colored wires go where, connect the 3 wires in any order you want and the motor will either spin in forward or reverse, if it does spin in reverse just switch 2 of the 3 wires and it will spin in the correct direction....you might want to solder on connectors in the beggining to test the direction
