Originally Posted by blueb8llz
so for all you guys that cant run the software, does this mean you cant run your cars either? or is there a default so you can still run your truck but just cant mess with the curves yet? if there is a default, will it work on lipos and does it have a default lvc? or is default only programmed for nicd/nimhs?
I can reinstall the older version that I downloaded a few weeks ago, but it doesn't allow me to set the lvc on the Monster above 17.1 volts. I can still run it just without lvc.
