05.12.2008, 10:59 PM
Sounds like you have 2 different pitch gears. Any chance of a pic? Or maybe measure the diameter of the pinion in mm. If it is a 24t mod1 pinion then it should measure 26mm across at the widest point. The stock spur is 32p, and they are not compatible at all.
