MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
05.12.2008, 11:29 PM
Originally Posted by bribeguy View Post
I was trying to build up the FLM kit using parts from an older Savage 25 kit. Apparently, when HPI redesigned this truck to the Savage X, they shortened the front & rear plastic skid plates by 1/8" - 1/4".
Since it would appear that the FLM kit is designed around the Savage X, using the original style plastic skids, leaves you with almost a 1/2" less room then is required by the FLM center skid.
Go figure.
Not a big deal, but definitely a surprise and a head scratcher at the time.
You learn something new every day. I have both skids and I never came across this issue. I must have swapped to the X skids before doing the swap to the flm kit.
