jordan...
one.five.two.seven
05.13.2008, 08:50 AM
If your front dogbone is that short, it should in theory be bulletproof because there's not much that can bend or break. About how long would your rear dogbone have to be?
that equals a rear dogbone length of 7 inches
if you look at the first pic, you can see the centre diff cup is past the SS arm though, so i would have to mount the unit further back, which means the motor might not fit. Maybe if someone hadn't gone overboard on the motor, then this setup would be way easier to install
what can i say, i NEED power
