05.13.2008, 12:48 PM
The official stand of Castle is that any pack that can handle 75A continuous, and 150A peak is sufficient for use with the MMM.
Patrick
Is this for 4s or 6s? If so then the 4000 packs should do, while a bit close they are rated for 80 amps cont. The 5k packs may be a better bet, at 100amps cont they offer a 25% margin.
How are you determining the 75amps? What motor are you basing this on?
Thanks for the info Patrick, much help you are!
