Matthew_Armeni
Matthew_Armeni's Avatar
05.13.2008, 01:03 PM
Originally Posted by jfruge View Post
Matthew, that is what I ordered for my sons 8ight conversion. What gearing are you using on your 4S setup? How is the runtime so far?
Thanks,
I'm running a 13t clutchbell and getting awesome runtime. I ran 2 5min qualifiers and 8 min of a 20min main (had the dogbone end of the center drive shaft eject after I cased the top of a jump). I don't quite remember the mah I was putting back into the pack after each qualifier (a Hyperion 16c 5350mah) but it was about the same if not a little less then tekno was putting into his and he was running a 1509 2Y and a MaxAmps 20c 6000mah with the same gearing. He finished the 20 min main with some to spare so I could have done at least 15min on the Hyperion, maybe 20, but I wasn't running that pack in the main, I don't like to run my pack until they dump, I was using a MaxAmps 20c 6000mah. We were both running MM with a fan, Castle BEC. This is racing so bashing should yield longer runtimes.
I'm also like their 1300kv 60mm in my 8T geared with a 14T bell. Running a Hyperion 18c 6s 4250 through an un-modded MM, Castle BEC, no fan. Haven't track tested this yet, but it should be a good setup.
  Send a message via AIM to Matthew_Armeni
