Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
05.14.2008, 12:18 PM
Originally Posted by nativepaul View Post
Good NiMhs are capable of that and more, holding reasonable voltage while doing it, just not for long, F5B flyboys were pulling over 300A from NiMhs in 3 second bursts before they switched to LiPos and boat and pylon guys were pulling close to 100A continuous, but at those levels your lucky to get half a dozen decent runs out of a pack before it either significantly drops capacity and voltage or goes pop.
100% correct...I'm one of those pylon guys...100A continuous plus in my F5D's...the batteries get about 10 cycles and then I throw them away. Same for the F5B guys. :)
For "getting away with batteries that handle less than 75A", NO, DO NOT DO THIS. If the controller fails due to ripple current we can't cover it under warranty, and you may lose your batteries in the process. Better to buy expensive, buy once.
Joe Ford
Product Specialist
