skellyo
skellyo's Avatar
05.14.2008, 01:28 PM
Ok Castle guys, explain to me how guys are killing the internal BEC with "poor batteries".
http://www.rctech.net/forum/showpost...5&postcount=22
As Quoted by RURC on RCTECH.net:
"Castle just called me at 1:10 on Wed the 14 of May. It seems that my thought on magnetic field collapse causing a voltage spike are correct. For the internal BEC problem. Also I have been confirmed that poor batteries are also to blame. As I was told the BEC problem is going to show itself within the first like 10 minutes of usage generally. If you dont have a problem dont send it in, it will be returned to you. The future of this problem will be take care of at Castle. As I understand it there will be a upgraded component installed to prevent this from happening. But like I said if yours is working it should be fine. Again they told me that this problem should show itself within the first 10 minutes."
And why the heck are you guys calling someone that doesn't even have a MMM to explain to them what problems you've seen? I'd really like to know if you have this guy on payroll as a contractor?
