Originally Posted by Pdelcast
No problem,
Use about 50-500 ohms or so (value isn't that important), 1 watt minimum, surge rated resistor.
You will lose that "MANLY" pop when you plug in the battery though... it's very cool on the SHV with 20S and 4000+ microfarads of capacitance... sounds like a gun going off... (We added an inrush current limiter circuit on the SHV, 'cause connectors would die in about 3-4 plugins...)
I like the pop
. It scares the crap out of my friends and it gives that "I'm tough effect".
