bdebde
That's All Folks!
bdebde's Avatar
05.14.2008, 10:06 PM
No problem,
Use about 50-500 ohms or so (value isn't that important), 1 watt minimum, surge rated resistor.
You will lose that "MANLY" pop when you plug in the battery though... it's very cool on the SHV with 20S and 4000+ microfarads of capacitance... sounds like a gun going off... (We added an inrush current limiter circuit on the SHV, 'cause connectors would die in about 3-4 plugins...)
Cool, thanks Patrick, I have my 6s batts set up for the resistor already, Just have to wire the Monster up when it gets here.
