05.15.2008, 01:03 AM
OK then, the two speed will allow you to choose more aggressive spur/pinion combos because first gear will get you going and second will get you the top-end. You could easily go with 40/16 or maybe even 40/18.
But, just remember that you will have to keep mechanical brakes, and unless you retain the stock (weak) reversing mechanism, you won't have reverse.
