MetalMan
MetalMan's Avatar
05.15.2008, 02:27 AM
You can use the Kyosho 46t plastic spur gear that RC-Monster carries, and it is advisable to use to reduce wear on the pinion and to also decrease the noise between the gears (steel pinion + steel spur is pretty loud).
