Thread: 9xl on 4s lipo
BOOGIE444
05.15.2008, 09:44 AM
Originally Posted by dpb318 View Post
that sounds good, i think im going to go for the mmm just to be safe, id rather not risk it
how much run time should i expect with the 8000 lipo
Edit: and what would be good gearing
Run time depends alot on gearing, having said that you should at least get 20min on the battery. Although the feigao might get too hot for that much continous running, make sure you get a rc-monster heatsink clamp. I am thinking a 20 tooth pinion would be about right with that KV of a motor, just watch your temps and see what gearing works for you. I bet its going to be some were between 18-22 tooth with that motor based on a 48 tooth spur gear.
