xtremelimits285
E8ight T
xtremelimits285's Avatar
05.15.2008, 02:57 PM
Originally Posted by rhylsadar View Post
i just take this quote as an example.
i wouldn't be too fast with a judgment. RURC may have a kind of a 'special' way to express himself sometimes and that may easily sound 'arrogant'. however there is no doubt that he has lots of experience and from what i read for years in the rcu forum his informations are mostly not bs but rather correct. maybe he didn't get it exactly right this time. idk but it has been stated here again that lower quality batteries may cause a problem for the esc. so the basic message isn't that wrong. and he is sure not just some trashtalker that knows nothing.
btw of course it was possible to build a brushless 8th scale models many years ago. it just wasn't as popular as nowadays. i do not have that long time experience but when i got my first converted savage in 2003 there wasn't much talking about brushless monsters on any internet platform. and i have no doubt that there were some people out there that already converted some trucks or buggies before 2000. so a guy like RURC may easily have around 10 years of experience.
bye
rhylsadar
i know he knows stuff....ive read older post of his too...
but he kept saying all maxxamp lipos wont work with the MMM..
and flat out said ployquest(enerland) packs are junk..lol
he hasnt used them in a year an said they wont work with the MMM...
he said u need 40C lipo or ull fry ur MMM
he said he has been following the thread...
IF SO HE SHOULD SEE 50% ARE RUNNING MAXXAMPS(20C) IN THERE 1/8th scale Conversions, AND 50% ARE RUNNING POLYQUEST/NEU(ENERLAND cells)25Cor30C...
this is with Mamba Maxs an a few other esc's..
i layed off him but he needs to get cought up, an See that most people killing there MMM, are running the same combo/car/motor/gearing/ an same GOOD LIPOS that can do 75amps cont.(if not more)
An were all running fine(some cant make 20mins or are overheating there esc's).....
btw he told everyone he had a 300Amp ?shulets? esc
lutach asked for some pics, an RURC is ignoreing him
Originally Posted by sleebus.jones View Post
15C in itself means nothing. You have to have an MAh rating to go with that. I'd look for 75A or greater continuous capacity. If you can do that, you should be fine.
YES, if u have batterys that can do 75A ull be fine
dont run any maxxamps smaller then 4s 5000mah(thats the limit)...
4s 6000/5s 6000(should be fine just dont push them, dont set acc.limit under 20% for safety, id set it at 40%-50%-60% or 70%) u dont need under 20% ull just wheelie anyway)
3s 8000/ 4s 8000, are good(5s 8000 are good but a bit to heavy, only good for long speed runs)....
As for Neu/Tracpacks/ Polyquests/ Enerland cells
4s 4000+/ 5s 4000+ / 6s 4000+ 25C (will work fine)
4s 5000/ 5s 5000 / 6s 5000 25C (will work fine)
4s 6000/ 5s 6000 / 6s 6000 25C (will work fine)
4s 4000+/ 5s 4000+ / 6s 4000+ 30C (will work great)
4s 5000/ 5s 5000 / 6s 5000 30C (will work great)
4s 6000/ 5s 6000 / 6s 6000 30C (will work great)
NEW 35C / 40C / 45C lipos comeing will be the best to use with the MMM
as we car run smaller packs an make 20 min mains.
PLUS u will beable to have a 1/8th scale land missael
Gary Antonietti #9
Losi 8ight T - Monster Mamba - Neu 1515 1y - MaxxAmps 3s/4s/5s 8000mah - Futaba 2.4GHz Tx/Rx 6EX - Futaba S9351 servo - 15/46t gearing
FTT3 -Mamba Max - 2s 8000mah
  Send a message via MSN to xtremelimits285
