Originally Posted by Joe Ford
Gents...the higher the C rating the less resistance in the pack and the cooler the pack will stay under the same amp load. Minimum of 4000mah and 20C is my recommendation. Obviously, the higher the capacity or the C rating, the better off you are.
if only everyone could understand this. not to be rude but it is not a hard concept. yes takes a little knowledge but anyone can learn this.
