Thread: 2p charging
MetalMan
MetalMan's Avatar
05.15.2008, 07:26 PM
It's easy enough to check the voltage of each cell in the pack using a DVM (digital voltmeter). Of the maybe 6-8 Dewalt packs I've come across, I'd guess half of them have had a cell or cells of lower voltage than the rest. If that is the case, you can use the resistor charging method BrianG outlined above to charge up the low cell(s) using the other cells.
