coolhandcountry
coolhandcountry's Avatar
09.22.2005, 08:34 AM
Okay! I was talking about the little finger looking ordeal that come out of the slider. I don't know the name for them. If you tighten the allen screw up a little bit it helps. It is inside the trans. On the out put shaft. You have the slider and the foward and backwards gears on the shaft. You need to adjust the little fingers type things in that area. I would use names but not sure what it is called. Tight the screws up a touch so it don't come out as easy. What happens is that the part is out and it won't pull the slider back to reverse. Sorry if confusing you. I had same problem back in the day on my tmaxx as well.
Peace!
Country
Help support the
Rc-Monster
Buy here
