09.22.2005, 10:19 AM
is the 9l the best overall for the E-revo type of truck? I want decent power, but good runtime is also important. Would it be wise to choose a different motor (or even this one) and run on 12 cells instead? I saw the one MGM controller is only 180 and can support up to 12 cells, is this better than the warrior 9920?
or would I have to get the higher rated mgm?
also, looks like the 9l has 5 mm shaft. can you safely just bore out a normal 32pitch pinion?
