azjc
05.18.2008, 11:41 PM
Hey guys, ive decided to get a Traxxas Rustler Vxl, I had an xl-5 rustler and u could run the thing into a brick wall and it would just bounce. So i plan on getting a 3300mah 3s zippy pack for the truck, is there anything i should know about this setup or truck?
If i want to e really daring ill buy a 12L, and run the mm on 5s in it
Jeezemax(sp)- im coming after your record
I wouldnt say the rustler is that rugged, I have crashed into curbs and assoted thing sticking out of the ground at less than WOT and broken front end parts, including RPM castor blocks and front bumper, but I agree with Pimp about using a larger battery, I would nt go less than a 5000 mah, you could go with a Zippy or True RC if on a tight budget
http://home.comcast.net/~truerc/read...eady_packs.htm
http://www.hobbycity.com/hobbycity/s...idProduct=6350
