tha5150
tha5150's Avatar
05.19.2008, 11:06 AM
You can take a AA battery and touch it across each phase. When you do this, the shaft will turn a little. Each phase should turn the same amount and speed.
I don't really think it's a fully blown phase though since the motor does turn.
yes the motor turns.
how do i test the AA method exactly? touch one end of the battery to one wire and the other end of the battery to another wire? making sure to touch the +end of the battery to all three wires? i want to do this tonight to eliminate the motor. but then, how can i test the MMM to make sure that isnt the problem or make sure the MMM and the motor are both bad. just my luck.
