05.19.2008, 11:38 AM
Originally Posted by BOOGIE444 View Post
THANKS!!!
I never did this calibrating like you described. Do I have to do this every time I turn on my esc / radio?
No, It saves the settings. You do need to calibrate the esc to your radio, even if it does arm without doing that.
Your gearing may be too tall and the battery voltage is falling enough to hit the lvc. I just mentioned the radio settings as I had that problem before.
