bl-is-future
bl-is-future's Avatar
05.19.2008, 11:52 AM
Originally Posted by BOOGIE444 View Post
If I change my throttle trim settings AFTER calibrating my radio & esc do I have to re-calibrate the esc / radio again???
just make sure your trim is at center BEFORE calibrating and all will be fine. Besides throttle trim should not be changed. If you had to change it to keep the truck from moving you DEFINITELY need to calibrate it. From what you say i really think calibrating will make a huge difference. If not well it wont hurt to calibrate it.
