bl-is-future
bl-is-future's Avatar
05.19.2008, 12:06 PM
Originally Posted by JOEX View Post
That's why i'm using the $3.50 knock offs
in that case hook it up and go for it. They say if the MMM is going to fail it will fail in the first 10 min of running it. I have ran over 3 cycles through my MMM and has not had a problem.
You proly know this but make sure you set the ESC to brushed mode.
Also remember to set it back to Brushless when you put the brushless motor in.
I forgot to set a MM back to brushless once and i cooked it!
