azjc
05.19.2008, 08:39 PM
Originally Posted by q8-maxx View Post
Differential Ratio: 2.8461538461538462
Transmission Ratio: 2.111111111111111
Other Ratio: 1
Spur Tooth Count: 36
Pinion Tooth Count: 20
Total Voltage: 18.5
Motor KV: 2000
Tire Diameter (inches): 5.6
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 1.8 : 1
Total Ratio: 10.81538 : 1
Tire Circumference (inches): 17.59 inches (446.86 mm)
Total Motor Speed: 37000 RPM
Vehicle Speed: 56.99 mph (91.55 km/h)
Effective Speed Rate: 3.08 mph/V (4.95 kmh/V)
Estimated Adjusted Speed: 53 mph (85 km/h) - 8% loss
Effective KV Value: 2000
KT constant: 0.68 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
5.6 stock revo tire :)
you do have a pretty big pinion I would go with a 18 tooth , your tires will balloon that would be ok for your on street speed runs but if you want to off road at all gear it for 40-45 mph, also I would stick with the 5s
