05.20.2008, 11:09 AM
Main reason for locking a 2 speed in one gear is to eliminate the one way bearing and use the motor brakes. If you do not mind mech brakes you can leave the 2 speed. My savage has that setup and it works fine for me. I did some adjustment to get it shifting at the correct time. I think I raised the shift point, so it would stay in 1st longer.
