05.21.2008, 12:15 PM
Originally Posted by jzemaxx View Post
That motor should be able to pull it that fast. The calculator above 75 though starts becoming in-accurate. The drag factored in must not be enough......
The drag factor is a VERY rough estimate. In very streamlined setups, the factor may be too high; in not-so-aerodynamic setups, the drag may be too low. So, I opted for "about in the middle". A MT is much different than an on-road car.
If the mood grabs me, I might add a drop-down box so the user can select vehicle type. Similar style vehicles should exhibit somewhat similar drag characteristics.
