Originally Posted by crazyjr
Thanks Lutach, So the graph is for different voltages with the same motor? I know the motor would wake up with more voltage, but want to do this on a budget. My plan is for using a MGM 16024 i got laying around (got to send it in for a glitch and update programming. Honestly, the motor on 6s is awsome
You should see them over 30 volts. With 8S you will see a completely different motor, even though you only went up 2 Lipo cells.
