azjc
05.21.2008, 06:01 PM
Originally Posted by 1maxdude View Post
Hey, you should probably toss your newly hardened gears in your oven at home and leave them in there for 2 hours at 400 deg. or so. Right now they are probably pretty brittle and you wouldn't want to start shearing off teeth.
to remove the brittleness you need to temper the gears after you harden them, also quenching in water causes a fast temp drop which gives the you the hardest result but makes it the most brittle and gives you the highest chance that you will get warping...in the past I have heated parts to about 1500 degs and than quenched in motor oil, I than brush off the carbon residue and reheat to about 500 degs to temper
here is a link to help explain the hardening process
http://www.armourarchive.org/essays/...treating.shtml
