Originally Posted by BOOGIE444
I have the punch / traction control turned all the way to the max on my MMM in my savage but its still not enof. The savage still wheelie's and burns out too much for my taste so I want to program the throttle curve to tame out the bottom end to make a smoother response.
So what would a curve look like that would help tame the accelartion of this beast? As I dont really understand the throttle curve graph & stuff that the MMM can do.
set timming to - 0%
acceleration/tracion to - 100%
(also higher ur lipo cutoff from anywhere 0.2v-0.8v higher then what u have, this will stop the car from pulling alot of amps AND it helps tame ur bottom-end alittle)
for the THROTTLE CURVE,
make it look like a half-pipe or quater-pipe..
(an play with it for 1 to 2 packs, as u can tune out ALOT of bottom-end Tq/Hp) run it for 2mins if u dont like it try pulling it over an down more around 30-70%, takes a lil bit but ull see how what chanes what
make it smooth curves btw..
