05.21.2008, 06:34 PM
Originally Posted by DLS II View Post
At the moment the battery is 1p. I've got a MM but would like to have a MMM. Diff ratio is 3.3 and tire size is 4.375 dia. Don
The mm is fine up to 5s a123, just use and external bec and disable the internal bec in the MM. 1p should be ok, to keep the weight down, but you will get 15min runtimes or so.
Forgive me, my earlier advise on the 42-60-800 was not good.
I would say that you should run 5s a123, a 600-650kv outrunner, and the MM. Speed will be in the low 40mpg range, which should work fine. The rimfire 42-60-600 would be ok to use, maybe go up to a 4120/14, 660 kv, outrunner, as those are very nice motors, and they will work well in your application.
http://www3.towerhobbies.com/cgi-bin...?&I=LXPPX8&P=7
