Thread: 4S in Buggies
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
05.22.2008, 01:00 AM
Originally Posted by MetalMan View Post
4s is often plenty to surpass the nitros in both acceleration and top speed. I'm running 4s with a Neu 1512 2.5D/F in my Hyper 8, geared for ~45mph, and everything (MM + batts + motor) run at very acceptable temps.
What gearing do you use in the Hyper 8? To get the 8ight to go 45mph on a 1512 2.5D & 4S would require a 17T-18T Pinion and 46T Spur. On 5S would require a 14T pinion. What run time you get?
How much extra run time would I get on using a 5S 5000 instead of a 4S 5000?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
