Hypersprint
05.22.2008, 10:23 AM
Yes, the .5v to .7v was read at the throttle signal cable, I only showed you the 10ths but my little meter displays 1000ths. I did not write the full numbers down but if it would help I can read it again. The truck is using an Rx pack, but until recently the ESC BEC was not disabled. I bought the truck already converted and did not notice that the ESC BEC had not been disabled until shortly after the truck began to run bad after a fairly mild rollover. So, yes the truck use to run like a bat out of you know where.
I don't believe it could be the LVC, I am reading 16.25Vm on my Watts Up meter.
Thanks for your help guys
Rob
Thanks
Rob
