rabosi
05.22.2008, 12:35 PM
2 MMMs. 2 dead fans. So far batting 1000. Both have less than a couple hours of run time.
Here is my solution. See picture below.
I'm pulling the dead fan and strapping a 25mm fan to the top over the fan hole and letting it blow into the case. The 25mm fans I was using on the MM and R1Pro are much more robust. I wish I could remember where I got them. I bought a lot of 10 for a good price like a year ago adn now I cant remember where I got them. Anyway, the 25mm fan moves more air than the 30mm fan that came with it. I can feel stronger air flow comming out the side vents of the MMM than with the stock 30mm fan.
Not pretty, but it works.
Wouldn't the 25mm fan fit in the stock fans spot?
