Yeah, getting rid of that fan, cutting away the top of the case, and maybe even replacing the heatsink is one of the first things I'm gonna do when I get a MMM. I too hate fans and think they are just a weak spot - and if a system NEEDS a fan to stay cool, then the components were not chosen appropriately for the speed/application it is being used in.
So, are you saying it's not a 200A ESC? What would you rate it at, taking into account temperature derating since these things are never at 25*C?
What's the FET part number?
I'm kinda "meh" on the built-in switching BEC thing. Personally, this is how I think ESCs should come:
- ESCs rated up to 2s can use a linear BEC since the gains with a switching are minimal, if any.
- ESCs rated up to 5s should have the linear BEC, but the output to the Rx be auto-disabled after 2s voltage level forcing people to use external one. The linear BEC is fine for just powering the brains since load is really low.
- ESCs rated over 6s+ should be Opto.
