Thread: Lehner 2240
lipomax
02.25.2005, 12:44 AM
Promod, when making those speed runs in the yard, when the voltage dropped from 24 down to 17 - was that during the peak amp draw? What kind of peak amp draw are you seeing? Have you seen occasional peaks that are WAY too high? Generally, I see peaks at 1300 watts with 6s lipo, 1700 watts 8s lipo. But occasionally, it'll pick up spikes that are more than double the usual amp draws. Of course those peaks depend on motor and gearing, but what kind of peak amps are you pulling? Can you post the .cdr file?
