05.23.2008, 10:53 PM
The medusa 2200kv 60mm motor should work fine for you. You could use a MM, but you will need an external bec, and possibly a fan. So the MMM would be the best bet as it has all of those built in. Pity it is having some teething issues, but it is the best bet.
