Originally Posted by Crt-Racer
I really didnt want to buy that hyperon charge since ill be charging high voltage, high mah packs (4s, 5s and 6s at 6000mah)
So the hyperion balancer will work on the super brain? Where would the plug be on it so i can search it up?
ac/dc chargers usually dont have much output (50 watts)and if you want to charge @ 1C with the packs you have listed you will need an output of at least 100 watts and allow yourself extra 20% for lost effiency so if you need 80 watts you will need to charge @ 100 watts, I have the 0610i and a 18amp PS and I have plenty of room...the charger can output 250watts and the PS is good for 270 watts before the 20% is subtracted
