05.25.2008, 09:58 AM
Are you going to leave the 2 speed and mech brakes in the savvy? If so the MM should work fine. You will need an external bec, like the ccbec, and remove the red rec wire on the MM to disable the internal bec. Depending on how much airflow you have inside the body, you may need a fan on the MM. Otherwise they are a decent esc for 4s usage. Plus you cannot beat the price and versatility!
