09.24.2005, 12:55 PM
you could get the Power polese which are 45 amp rated from robotcombat, since I had a whole bunch of the black and red covers.. I decided just to order the contacts....
the pole conectors 15 amps, 30 amps, and 45 amps both use the same housing.... And I do agree taht deans are good for 80 amps... but the solder is the week part... my Crimped 45 amp power pole stays cooler than my soldered Deans 80 amps...
So the batfish is correct, the solder is the week part.. well.. that's my opinion.. :)
