Originally Posted by pb4ugo
Yes. I think the difference in effeciency between a 10s1p setup and 5s2p at this point would be minimal. 5s controllers can be had a lot cheaper and with US support than 10s controllers. Mind you I insist on controller brakes.
than you will have no increase in power you will double the capicity, unless your goal is to be able to run twice as long without changing packs you will have a lot of extra weight with no increase in power and that will increase your power usage
just my .02
