Sparky
Sparky's Avatar
05.25.2008, 03:30 PM
Originally Posted by e-mike View Post
150f without a fan wow!!!!! im interested by your issue solution,, i want more detail for the modification to prevent some issue....if i understand you put a little piece of rubber between the case , the fan plug and the big black component????
i can open my mmm ???
I will try to clarify. The gasket is to rise the ESC board up in the case so the components on the bottom side are farther away from the bottom case. Nothing should touch any of the components on the board. So the gasket is like a little rubber ring around the outside.
I also have holes in my car body next to the ESC so air is moving over the controller. That is the only reason I'm able to get by without a fan.
