MetalMan
MetalMan's Avatar
05.26.2008, 03:04 AM
Originally Posted by TDC57 View Post
I’ve got some questions for the team / family (hope you don’t mind)??
1. What is Drooop?? And what setting do I / have you used with any success?
2. Isn’t there supposes to be some kind of dust boot covering up the ball joints?? They are totally exposed and I can see the front tires kicking up everything on my rears every time when driven?? What am I missing here??
3. What is going to be braking on here, I hate beaning down (much like you) and feel the need to order extra parts, got any suggestions??.
4. Does anyone have a SETUP sheet they can send me?? This buggy has sooooo many different options I don’t even know where to begin other than what the instruction recommend..
5. Not that she’s running yet, but how do I judge service on a buggy and to what length is involved??, a complete teardown or just regular maintenance??, what is regular maintenance on a buggy anyway??
6. What is the recommended shock rebound setting for buggys?? The instructions give me three options (low, 50% and 100%) what are your thoughts / suggestions..
I'm SSSssoooo sorry for the newbie questions!! andThanks SOOOooo much for your time and have a great one!!!
Shaun.
1) Droop is commonly referred to as the amount of down-travel that the suspension is limited to. The setting you use often will depend on the track/surface. For example, on a track with HUGE jumps you will want to unscrew those little set screws to increase down-travel, as this will allow your suspension to work more. However, too much can be a bad thing because it will allow more body roll which decreases handling capability (sway bars are a fix for this, though).
2) Which ball joints are you referring to? Typically 1/8 buggies/truggies don't use dust shields anywhere except on the shock shafts. I never really thought about it it, but I suppose it might be because these vehicles are able to withstand such punishment. (Are you comparing the dust shields on the Revo?)
3) Obviously I can't answer this question 100% accurately, but in general you might want to stock up on front and rear arms (upper and lower) and if there are plastic arm mounts (or hinge pin plates, or whatever you want to call them) those could also be good candidates.
4) Do the instructions have a reccommended setup? That's always a good place to start. Aside from that, I am of no help here.
5) Things that often wear out the fastest are hinged suspension components, such as the suspension arms, arm mounts, rear axle carriers, and front c-hubs (if the front suspension uses a c-hub). This will be different from buggy to buggy based on the design (for example, my new SH buggy uses rubber bushings between the hinge pins and the suspension arms to reduce wear). Shock seals also wear out, and you can buy shock rebuild kits which include o-rings, shock pistons, etc.
I am not a big fan of doing maintenance on these buggies, so I just like to wait until I notice an unacceptable (by my standards) amount of slop in various parts to replace them.
6) I don't yet have enough racing experience to thoroughly answer this. That said, I tend to build my shocks with between 25-50% rebound, and make sure that all the shocks (or at least the fronts and the rears) rebound the same.
Any more pics of your awesome buildup?
