MetalMan
MetalMan's Avatar
05.26.2008, 10:55 PM
Typically only the motor determines the current draw. But you must also consider that the motor will pull current based on the input voltage and the load placed on it. If you are simply increasing the voltage, then the motor will require more current, but at the same time will also put out more power.
