glassdoctor
TEAM FUSION
glassdoctor's Avatar
05.27.2008, 12:52 AM
I know the gearing is a bit tall, but it does pull and accelerate very well, and there's only one way to find out what it can do. :)
I'm sure dropping about 2 teeth would be about right for general racing, etc. I'm curious to see how it will run on the track. I'm looking at the 36-60-2000 as a better motor, but others are saying the 50mm does ok, so I wanted to try one. I think the 6s and low kv will give it the best chance to work, but it will probably still take a milder speed setup. I need to clock mine to see how fast it actually is...
This motor is spinning slightly more rpm than my 1509 4s setup
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
