Thread: Losi eight Q's.
8ight
ilpufxit
ilpufxit's Avatar
8ight - 05.27.2008, 05:14 PM
I'm running the same motor on 5s and it rips. It will work on 4s with MM. The battery mount should fit, you just need to check body clearance. Battery height of 38-40mm is max unless you want to cut or raise the body.
