05.27.2008, 09:15 PM
You should be fine as long as everything is placed properly and the MM settings are setup properly.
Not sure about that satement. Direct to tire will take quite a bit of startup power, and may cog due to the drive ratio. For the price of the outrunner it is not an expensive gamble. Motor kv will be very important, no room for error on this one.
