Originally posted by MetalMan
The cells in the BalancePro packs are just the standard Kokam 3200mah cells. They are just bundled up with some electronic equipment under the shrink wrap, and then are called BalancePro. So, you could still use the BalancePro charger with the Kokam 3200mah packs, but you will have to buy a charging cable to hook up to the battery.
Although I don't doubt this, there are some things I just won't experiment with myself. I'd rather purchase the assembled, approved packs to use with the BalancePro charger.
I do have a couple of the 3s 3200 packs as well; I just use the ICE to charge them at the normal 1C and I don't balance them. If I buy any of the standard 2s 3200 packs I'll be using the ICE on those, too.
