MetalMan
MetalMan's Avatar
09.25.2005, 07:05 PM
Originally posted by aqwut
I think the Kokam/FMA lipos are the best.. they have a 20C continuous discharge rate.. every other pack Tanic, Thunder are 12 to 15 coloumbs discharge rate..... Lipo are good for hot, cold.. whatever.. there aren't any liquids inside.. it's just metal and plastic... but Lipo's are a lot more sensitive.. if you puncture it, it will burn.... Lithium deteriate if exposed to air, but when lithium touches water... WOAAAHH BABY... It's burn and glow bright red.. it'll burn a whole in Cement...
I really like the astro flight charger... it's very consistant in charging... plus it can do 9 cells....
The Kokam cells also weigh quite a lot for their "20C" continuous rating, which they aren't capable of. They would be better labelled as heavy 15C continous cells that are more robust than standard LiPo cells.
Lipo cells actually don't work well when cold. Performance is increased when their temperature gets to 100 deg. F. There is no elemental Lithium in these batteries, so if the insides of one of these cells touches water, there won't be anything magical.
The Astroflight 109 isn't actually what might be called a standard LiPo charger. Most chargers are "CC/CV", whereas the 109 is somewhat of a pulse charger, which will pulse the cells to 4.35v (this means that it can't really be used with balancers).
Originally posted by coolhandcountry
Do you see a difference between balanced and un balanced packs? If no difference why get them? If a difference how much?
If you have a pack with the taps on it can you charge it individaully threw the taps?
An unbalanced Lipo pack can be hazardous. When one is unbalanced, one of the cells can get to a higher voltage than the other cells in the pack during a charge, which will shorten the life of that one cell, thus creating a chain reaction of cells becoming bad. Also, if a pack is unbalanced, one cell can be overdischarged, causing damage to it.
Basically, a balanced pack will ALWAYS be better than an unbalanced one, in terms of performance and safety.
You can't really buy a balanced pack, as the only way to get something like a balanced pack would be to get one with cells that all have similar IRs (internal resistance). Maxamps is the only company that claims to make packs with cells that have a similar IR. This is not an option offered by companies, though.
A pack with taps is always a good thing to have. A pack can be balanced through the taps by charging each individual cell to 4.20v, as opposed to charging the pack as a whole (where imbalances may occur). Depending upon the type of taps, you can only charge at up a certain amp rate (limited by the resistance of the taps).
